garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 06, 2014Virtuoso
nothing install other than the transmissionr6 I did manually, and then the 'transmission' I did via apt-get to fix the dependency. A reboot fixed the "system->overview" page, but not the app list.
I'm going to just factory default again, re-arrange the array, and then go to sleep while it rebuilds. I'll let you know how things work out in 8 or so hours. :)
