garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 06, 2014NETGEAR Employee Retired
Did you use the same volume name or a different one?
Once the volume has synced up again you could try a reboot to see if that fixes it.
If there is still a problem then doing an OS Re-install and/or installing 6.1.9 RC11 over the top of itself may help.
