garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
Sep 06, 2014Guru - Experienced User
Note that with OS6, the apps are stored on the data volume (\data\.apps by default). That helps ensure that the OS partition doesn't fill. But it also means that destroying data volumes has implications on the apps.
Some apps seem to assume /data, so it is sensible to have one data volume with that name.
