garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
Sep 06, 2014Guru - Experienced User
I don't know the mechanism, but I have seen the available app list be blank for a while after install or an upgrade.
You should be able to install RC11 over itself from the web ui without changing anything. The front panel OS reinstall procedure should also work.
