garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 07, 2014Virtuoso
I needed the dmesg output from the device (see above for examples of what I need.) I'm trying to see how "usb_port_3:1" in the .conf file is getting translated to an actual usb port in the system. My first impression was to change the .conf file to use usb_port_1:2 (which is the device number in my kernel) but that didn't work... so I might be missing something.
Thanks
Gary
Thanks
Gary
