garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 08, 2014NETGEAR Employee Retired
garyd9 wrote: It sounds like this is probably an issue specific to my loading the OS6 on unsupported h/w and NOT an issue I'd see with a real 516? That's good to know.
Yes. Not probably. It definitely is.
garyd9 wrote:
The only leaves the issue of the USB devices becoming shares automatically with liberal permissions. (There are a coupe other things, but they can be worked around.)
So your settings changes are definitely lost and aren't applied you reconnect the same disk without reformatting?
garyd9 wrote:
By the way, I appreciate you taking the time to walk me through all this, mdgm. I realize that I'm probably a pain in the butt.
You're welcome!
