garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 08, 2014Virtuoso
mdgm wrote: So your settings changes are definitely lost and aren't applied you reconnect the same disk without reformatting?
garyd9 wrote:
The only leaves the issue of the USB devices becoming shares automatically with liberal permissions. (There are a coupe other things, but they can be worked around.)
I'm pretty sure of it. I'll re-validate this evening when I'm physically there (in about 10 or so hours.)
