garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
mdgm-ntgr
Sep 12, 2014NETGEAR Employee Retired
garyd9 wrote:
Q: I put the 6.1.9 RC11 of OS6 on my ProBE. Will I be able to update the 516 to the same RC (using a spare HDD) and then just pop the drives from the ProBE into the 516? (with a reasonable expectation that they'd normally work [if the drives are still functional]?)
Yes. Of course you would shutdown the 516 and remove the spare HDD before putting your array in the 516.
Also remember to wait till the NAS comes back up after you reboot it as part of the update process and check that the update went fine.
