garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 12, 2014Virtuoso
mdgm wrote: Yes. Of course you would shutdown the 516 and remove the spare HDD before putting your array in the 516.
Also remember to wait till the NAS comes back up after you reboot it as part of the update process and check that the update went fine.
Yes.
I'll also be careful to keep the drives in the same order. I'm assuming the bays are numbered 1 thru 6 working from the top to bottom on the 516? (On the ProBE, they are 1-3 top left to top right, 4-6 bottom left to bottom right.) (Although, I'm not sure its still required to keep the drives in order anymore with the newer firmware... is it?)
