garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
xeltros
Sep 14, 2014Apprentice
You should be able to modify file rights within GUI, file access tab. I believe samba uses the system users directly.
You are right they are in /media. I just checked. I don't know what is mounting them.
