garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
Sep 14, 2014Guru - Experienced User
Unfortunately the file access tab only resets the share root, it is not recursive. "reset" is hard-wired to factory default rights (guest/guest, wide open) which isn't what garyd9 wants.
xeltros wrote: You should be able to modify file rights within GUI, file access tab. I believe samba uses the system users directly.
