garyd9
Sep 04, 2014Virtuoso
"OS6" - a question or three
First, a direct question: I'm currently running my Pro BE's with 5 or 6 disks using "x-raid2" and "dual redundancy." (RAID6 with the xraid2 expansion scheme.) I downloaded the manual for one of...
garyd9
Sep 14, 2014Virtuoso
There's another monkey wrench... My environment is on a windows domain (ADS) so slightly different rules apply. I'm trying to find out what happens if I change perms from a windows server. I suppose it kind of depends on just how Samba preserves windows permissions. If they are stored and preserved on the USB device, it's not too bad. If they aren't (or if they are nuked when the device ejects) then that's no fix.
(Doing it from windows is a bit of PITA right now. All of my windows machines at home are unavailable so I'm having to VM from a mac.)
