ayairo
Oct 07, 2016Follower
OS6.5.2 → 6.6.0 after the update, Volume is no longer recognized
Or what did you do to can not be downgraded What would it happened in the update
- Oct 07, 2016
ayairo,
Your situation looks like a data recovery one. You should contact support if you are interested in purchasing a data recovery attempt.I noticed that you moved your disks to an x86_64 model (which one?) and then back to your ARM box.
mdgm-ntgr
Oct 07, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
- mdgm-ntgrOct 07, 2016NETGEAR Employee Retired
ayairo,
