davidr1
Mar 03, 2022Luminary
OS6 DISK TEST STILL GOING AFTER 4 DAYS
Hi NAS 314 4x4TB RAID 5 I started a Disk Test Mar 01, 2022 13:45:01 Volume: Disk test started for volume data It is still going (Mar 04 09:11) The only indication anything is happening is t...
davidr1
Mar 04, 2022Luminary
Any help at, please? It's still going Mar 05 09:06
Many thanks
David
- StephenBMar 04, 2022Guru - Experienced User
It's certainly running much longer than expected. My 4x10 TB system completes the disk test in less than 24 hours.
My recollection is that there is cancel control on the volume page - not sure about that though. Rebooting is another thing you can try.
After cancelling, it makes sense to download the full log zip file - looking to see if there are errors that might explain the slow completion.
- davidr1Mar 04, 2022Luminary
Hi StephenB,
Many thanks for your reply.
There is no Cancel button (6.10.6) on the Volumes page. So I did a Shutdown and it powered down straight away. A Cancel option on the page would be a good idea.
The disks are WD40EFAX and supported. I'll download the log.
Is it the DISKS log?
Many thanks,
David
- StephenBMar 05, 2022Guru - Experienced User
These particular drives are SMR technology, which have highly variable write speeds (they will become glacially slow when there is enough sustained writes to overwhelm their cache). Generally I don't recommend the current WD Red drives for ReadyNAS (several folks here have had trouble with them). Red Plus are CMR, so they are fine.
But still, the drives are only being read during the disk test, so I'm not seeing how the SMR would factor in.
There are several logs that I'd look in (including disk_info.log. If you can upload the full log zip to cloud storage (dropbox, google drive, etc), you can send me a link in a PM - I'll get back to you this weekend.
