davidr1
Mar 03, 2022Luminary
OS6 DISK TEST STILL GOING AFTER 4 DAYS
Hi NAS 314 4x4TB RAID 5 I started a Disk Test Mar 01, 2022 13:45:01 Volume: Disk test started for volume data It is still going (Mar 04 09:11) The only indication anything is happening is t...
Mar 05, 2022Guru - Experienced User
davidr1 wrote:
The disks are WD40EFAX
These particular drives are SMR technology, which have highly variable write speeds (they will become glacially slow when there is enough sustained writes to overwhelm their cache). Generally I don't recommend the current WD Red drives for ReadyNAS (several folks here have had trouble with them). Red Plus are CMR, so they are fine.
But still, the drives are only being read during the disk test, so I'm not seeing how the SMR would factor in.
davidr1 wrote:
Is it the DISKS log?
There are several logs that I'd look in (including disk_info.log. If you can upload the full log zip to cloud storage (dropbox, google drive, etc), you can send me a link in a PM - I'll get back to you this weekend.
