dtarin's avatar
dtarin
Luminary
Nov 28, 2020
OSX machines constantly disconnect from ReadyNAS
I have several OSX machines in my network and every single one of them has issues losing connection to the ReadyNas while in use.  Someone will be browsing the drive via SMB and then suddenly the connection will drop. While the users can easily reconnect, it is supremently annoying to be browsing and then have to reconnect.
OSX: 10.15.7
ReadyNAS firmware: 6.10.
Does anyone else have this problem?
I attempted to restrict the SMB version on ReadyNas to SMB 3.0.2 via the SMB Plus app.  I noticed it will not connect if I restrict it to 3.1 or greater.  Do I need to use an SMB version less than 3.0.2?
  • StephenB's avatar
    I'm not a mac user, but I believe you can see the version of the SMB that your macs are actually using by entering smbutil statshares -a in terminal on the mac. (I suspect that will only work if the Mac is accessing a NAS share).
    If SSH is enabled on the NAS, you can also see this info by entering smbstatus there (when the Mac is accessing a share).
    Once you know the minimum SMB version used by your devices, you can restrict the server with SMB Plus.
    dtarin wrote:
    OSX: 10.15.7
    You might want to try 6.10.3.  Though it might not help your main problem, there are some fixes needed for TimeMachine.
    Again, I'm not a Mac user.  I am seeing some reports of this happening with Catalina with various file servers (including Synology NAS btw).
    One suggestion I saw on Reddit was to disable "allow disk to sleep" on the Mac. no idea why that would help - but it apparently did solve the problem for that person, and it would easy to try.
    • dtarin's avatar
      dtarin
      Luminary
      Thanks for the info.
      I am running 6.10.3.  Typo on my original email!
      I'll turn off the allow disk sleep on a couple of the macs and leave it unchanged on the others.  I'll monitor the increase/decrease of complaints. =)
      As for smb status: This is is what comes back for all the connections.  Anything to be concerned about here?
      SMB_NEGOTIATE SMBV_NEG_SMB1_ENABLED
      SMB_NEGOTIATE SMBV_NEG_SMB2_ENABLED
      SMB_NEGOTIATE SMBV_NEG_SMB3_ENABLED
      SMB_VERSION SMB_3.02
      SMB_SHARE_TYPE DISK
      SIGNING_SUPPORTED TRUE
      EXTENDED_SECURITY_SUPPORTED TRUE
      UNIX_SUPPORT TRUE
      LARGE_FILE_SUPPORTED TRUE
      OS_X_SERVER TRUE
      DFS_SUPPORTED TRUE
      FILE_LEASING_SUPPORTED TRUE
      MULTI_CREDIT_SUPPORTED TRUE
      • StephenB's avatar
        Nothing to be concerned about, but it does confirm that OSX is using 3.0.2.  That explains why removing that protocol verison with SMB Plus resulted in failed connections.
ProSupport for Business
