malcor50
Sep 29, 2023Aspirant
page d'adminitration ne veut pas afficher
bonjour page d'adminitration ne veut pas afficher appres reinstallation du systeme d'explotation voici la copie du diagnostic fait avec raidar: Disk 1 has 1 Reallocated Sectors Disk 1 has ...
Sep 29, 2023Guru - Experienced User
malcor50 wrote:
Volume root is 100.00% full
/var is consuming 3591 MB
Ouch.
You'll have to either clean /var manually with ssh, or do a factory reset. My NAS has about 524 MB in var (948 MB total space in the root).
I suggest making a backup of your data right away, as it is at risk.
Disk 1 has 1 Reallocation Events
Disk 1 has 239 Current Pending Sectors
Disk 1 has 239 Uncorrectable Sectors
Volume root is degraded
The volume has degraded because disk 1 has essentially failed.
Though I suspect it is the data volume that is degraded, and that the root is also being reported as full.
You need to replace disk 1, but first you need to deal with the full root.
- SandsharkSep 29, 2023Sensei
StephenB wrote:You need to replace disk 1, but first you need to deal with the full root.
And, as StephenB said earlier in the post, back up the data. Do not attempt to replace the drive with a full root partition or without backing up the data, as a second drive failure will render your volume dead and the data on it will be lost.
- StephenBSep 29, 2023Guru - Experienced User
Also, the NAS configuration files are stored in the root, and they are easily corrupted when the root is full.
So back up first. Don't reboot the NAS or power it down until you've done that.
