malcor50
Sep 29, 2023Aspirant
page d'adminitration ne veut pas afficher
bonjour page d'adminitration ne veut pas afficher appres reinstallation du systeme d'explotation voici la copie du diagnostic fait avec raidar: Disk 1 has 1 Reallocated Sectors Disk 1 has ...
Sandshark
Sep 29, 2023Sensei
StephenB wrote:
You need to replace disk 1, but first you need to deal with the full root.
And, as StephenB said earlier in the post, back up the data. Do not attempt to replace the drive with a full root partition or without backing up the data, as a second drive failure will render your volume dead and the data on it will be lost.
Sep 29, 2023Guru - Experienced User
Also, the NAS configuration files are stored in the root, and they are easily corrupted when the root is full.
So back up first. Don't reboot the NAS or power it down until you've done that.
