junks00
Jan 04, 2020Aspirant
Password & reset
Hi Hoping someone can help! I bought my RND2110 V1 about 10yrs ago & only used it once then forgot all about it, just found i again but cannot remember any of the details on setup. I've manag...
JohnCM_S
Jan 04, 2020NETGEAR Employee Retired
Hi junks00,
Welcome to the Community!
You can reset the system to factory default by accessing the NAS boot menu. You may check this link for the steps on how to access the boot menu and then select the factory reset option.
Sandshark
Jan 04, 2020Sensei
Note that when you do so, the default password for your older NAS is netgear1, unless the firmware is really old, in which case it's infrant1. References you see to the password being "password" are for newer models. Note, too, that it can only use SMB1, which is disabled by default in current Win10. You have to enable it in the :Turn Windows features on and off" section of Win10 preferences. Before you go beyond the reset, you should update the firmware to the latest.
