mso345
Nov 29, 2020Aspirant
Password recovery is not available (RN10400) (no more warranty or service)
Hey there NAS-Community, unfortunately I have forgotten my password for my old NAS device. It is still working (So I can transfer Data from the NAS to my laptop) but I cannot access the configura...
Nov 29, 2020Guru - Experienced User
You can reset the admin password back to password by doing an OS reinstall from the front panel.
This won't affect your data, but will reset some other settings. The network settings will also be set to the default (DHCP with no bonding), and volume quota (on the volume settings wheel) will be turned off.
Information on how to do that is on pages 28-29 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf Be careful not to do a factory default.
FWIW, since anyone who steals the NAS can also execute this procedure, there isn't much downside to taping the admin password on the inside of the door of the NAS. That would eliminate the need to do this in the future. Though I do recommend logging into your NAS on a regular basis and looking at the logs, etc.
- mso345Nov 30, 2020Aspirant
Hey StephenB thank you so much for your quick reply!
I used to have a friend who was a technology freak and he urged me to buy this product and he did all the installtion and implementations etc. so I have not really a clue about this thing...
(I planned on putting in two more harddrives with the raid function to use all the space available and I thought bevore I do that I probably need to get the admin rights again and I also wondered about needing new security updates etc.)
The link didn't work but I found some results on google so I just need to find the right manual I guess?If it will reset some other settings how does this affect me or the handling of this device?
Yeah thank you for that tip I will do that directly afterwards!
But maybe I need to double check if I find a German manual just to be save with my mother tongue because I dont want to mess up the system^^
Again thank you so muchAll the best from Germany
- StephenBNov 30, 2020Guru - Experienced User
mso345 wrote:
The link didn't work but I found some results on google so I just need to find the right manual I guess?Somehow there was a space included at the end of the hyperlink. I've fixed that, so it should work now. I believe Netgear only provides English manuals. Regrettable.
At most you'd need to restore the original settings.
You likely already are using the default network configuration - if that is the case, you won't need to change anything there.
As far as volume quota goes, you can just re-enable it from the volume settings wheel (on the volume tab). If volume quota is disabled, you won't see the details of how much space each share is using on the share page of the admin ui.
- RikbJan 07, 2021Aspirant
I have a RN10400 that won't let me login after a firmware update last month
It has OS 6.4 i think
I don't want to loose my data by trying to reset so
If I remove all the drives and then reset to default pass word so I can access it through Raidr
can I just reinstall the drives in the proper order and not loose my stored data?
Or after the reset is the data on the drives inaccessable?
I have 4 x 4TB drives in this and don't want to loose all that data.
Also, In my searches it appears that the 6.? firmware allows larger drives on this NAS.
or am mistaken ?
Thanks for any help
