wagb278
Oct 28, 2016Star
phpinfo on ReadyNas
I cannot seem to get a phpinfo.php file to work on my ReadyNAS. Need suggestions. I am running NAS firmware version 6.6.0. I have the PHP file "phpinfo.php" in my "apps" directory but it does not w...
JennC
Nov 01, 2016NETGEAR Employee Retired
Hi wagb278,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- wagb278Nov 01, 2016Star
This issue is not resolved. I cannot access .php or .html files but would like to; so help is still sought.
- wagb278Nov 03, 2016Star
Further research into this has convinced me not to mess trying to get simple HTML and PHP files to work on my NAS.
What I was originally trying to do is to have a phpinfo() output from the NAS to be able to inspect the PHP settings and other information provided by that function. I still think that is good information to have available - maybe phpinfo() is something that could be added to the OS.
The directory /etc/apache2 includes a directory named sites-enabled containing links to "http.conf" files in /apps/<app-name> that in-turn include configuration settings. One of the configuration parameters is a Listen Port that probably requres registration with NetGear and using the development kit to develop applications. So adding simple HTML or PHP files instead of full applications appears to be something I don't want to mess around with and posibly break my NAS. I need my NAS for its original purpose of backup file storage.
- FramerVNov 06, 2016NETGEAR Employee Retired
Hi wagb278,
Not sure if this is related the Debian update on the ReadyNAS. Have you tried reaching out to the developer of the apps?
