Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
Pezman
Jun 11, 2012Aspirant
Your support request has been saved:
The reference number is 18753339, a representative will reply to you shortly.
