Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
mdgm-ntgr
Jul 14, 2012NETGEAR Employee Retired
Put a spare disk in the replacement NAS (must not be from your array) and make sure that the firmware is updated. If it is running 4.2.15 or earlier, I would update to 4.2.16 (http://www.readynas.com/RAIDiator_x86_4_2_16_Notes) first. 4.2.21 should be fine. Verify that the update is successful. Power down, remove the spare disk and migrate your disk across as per the FAQ. If you still have issues I'd suggest following up with support for further assistance.
