Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
mdgm-ntgr
Jul 14, 2012NETGEAR Employee Retired
Do a factory reset with just that drive in. If it doesn't work connect the disk to your PC again and delete the partition. Put the disk back in the NAS and do a factory default again.
