Pezman
Jun 10, 2012Aspirant
Pioneer Pro - CPU Fan Replacement (case:18753339)
Hello, I have a Readynas Pioneer Pro Business Edition. I've owned it for 3 years, and just discovered that it is from "Batch 1" which means my CPU fan has been running at 4,400 RPM for the last thre...
mdgm-ntgr
Jul 15, 2012NETGEAR Employee Retired
Well your thread title was a bit confusing and you never mentioned in the thread clearly which one you'd purchased but one would've thought support would've known which you purchased.
If you purchased the Business Edition I would contact support about it. They could arrange another RMA or possibly to fix the issue remotely depending on the availability of replacement units.
