kipome19
Oct 23, 2016Aspirant
Plex . Cannot launch
I try to launch my Plex App on RN 212. Initially it worked but all of a sudden I receive this error message: Emty resource error. Bad NML call. Code: 22002010000 Can anybody tell me what the...
mdgm-ntgr
Oct 23, 2016NETGEAR Employee Retired
Which firmware are you running?
Which version of the app?
Have you tried a reboot?
kipome19
Hi,
I use following:
Which firmware are you running - 6.6.0
Which version of the app - 1.0.3.2461 35f0caa
Have you tried a reboot - Yes, I did and also tried to turn on/off the app several times
Any idea?
- mdgm-ntgrOct 23, 2016NETGEAR Employee Retired
There is a known issue with Plex and the upgrade to 6.6.0. There is a newer version of the RN2XX app at plex.tv/downloads
But it is possible that you may still need a manual fix atm.
