rmdelatorre's avatar
rmdelatorre
Power adapter, ReadyNAS 212
As I moved apartments, I have lost the power supply adapter (the brick you plug on the electrical outlet) for my ReadyNAS.
What should I look for as a replacement? Where can I buy it?
I'd hate to buy the wrong thing and fry my NAS.
Thanks,
Rafael.
1 Reply
  • You need a 12V 5A supply with a 5.5/2.5mm connector with positive on the pin and return on the ring (which is standard).  12V power supplies designed for security cameras are good choices.  You may find one for LED lighting a bit cheaper, but LED lighting does not require the same regulation, so I recommend sticking with those rated for a camera.
ProSupport for Business
