  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi ggmasluka
    Welcome to the Community!
    This feature became a standard on SATA III rev 3.3, This type of drives are not tested yet for compatibility with the ReadyNAS systems and even HGST does not recommend it on untested Chassis.
    This is due to the drive's possibility to not spin up when 3.3v power is being provided in Pin3. It is recommended to use HDDs without this feature for now to avoid any issues.
    Here is a link to an article for HGST Power Disable feature and another post that may add up to this reply.
    Hope this helps!
    Regards
      • Marc_V's avatar
        Marc_V
        Hi ggmasluka
        That is good to hear though it's noted that the compatibility of the drive was based using the test from the same series which in this case might be a non-PD HDD. But still if you prefer to use it, As stated it may or may not spin up on the chassis.
        If you already have the drive it would be great if you can confirm the compatibility of the drive on your RN422.
        Regards
ProSupport for Business
