kevinngeorgia
Feb 08, 2012Aspirant
Power is out of spec
Just got a warranty replacement ReadyNAS 1100 and Im getting a "2.5v power is out of spec" 2.5v power is out of spec [expected: 2.5 current: 4.080]. [Wed Feb 8 09:00:31 PST 2012] Do I need to...
PapaBear1
Feb 09, 2012Apprentice
I would recommend you contact technical support and work with them. You may want to refer them to your original case number and RMA number.
