dcmitchellsr
Aug 18, 2014Aspirant
Power Surge - No connectivity
We have a ReadyNAS 2100 that was working just fine and then the location where it is located had a power surge and it temporarily lost power. Power has been restored to the location and the ReadyNAS ...
mdgm-ntgr
Aug 18, 2014NETGEAR Employee Retired
Does the NAS show up in RAIDar? If so, what do you see in the Info (far right) column?
You can use a crossover cable for a direct-connect but an ordinary ethernet cable would work fine.
