kevinb1
Jan 21, 2016Aspirant
Power Timer not turning on OS6 FW 6.4.1 - Legacy Ultra 6
I recently acquired an Ultra 6 Plus, which I upgraded to OS 6, FW 6.4.1, for use in backups. The Power Timer function (which I liked better in the old NV+ models, since I could specify minutes) turns...
- Jan 22, 2016
kevinb1 wrote:According to the bios_ver.log, I have a 05/26/2010 FLAME6-2 V1.1 product.
Ah then this is not an issue with OS6 on legacy at all. There is a known power on issue with an old BIOS on an Ultra 6.
You will need to update the BIOS to the latest: 06/10/2010: http://www.readynas.com/download/addons ... .5-x86.binEasiest way to install would be to:
1. Power down
2. Remove your disks (label order)
3. Put a scratch disk in (must not be from your array)
4. Do a factory default (wipes all data, settings, everything)
5. Downgrade to RAIDiator-x86-4.2: https://community.netgear.com/t5/Community-Add-ons/Downgrade-to-RAIDiator-x86-from-ReadyNAS-OS-notsupported/td-p/859412
6. Install the BIOS update add-on7. After you get an alert that the add-on has installed successfully, reboot and check bios_ver.log to make sure the BIOS has updated.
8. Update the box back to 6.4.1
9. Power down
10. Remove your scratch disk
11. Put your disks back in same order as before
12. Set the power timer again and see if it works
Note that it is important not to interrupt the BIOS upgrade whilst it is in progress as it would brick the system.
kevinb1
Jan 22, 2016Aspirant
More info.
Rsync is running between 4-6am, and has not been going over that.
AV,DLNA, Transmission all off.
/etc/cron.daily has nothing in it.
/etc/cron.d contains:
frontview-backup frontview-volumeschedule poweroff
poweroff has the following entries:
00 00 * * 0 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 0 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 1 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 1 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 2 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 2 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 3 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 3 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 4 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 4 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 5 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 5 root /frontview/bin/autopoweroff &> /dev/null 00 00 * * 6 root /frontview/bin/autopoweroff &> /dev/null 00 13 * * 6 root /frontview/bin/autopoweroff &> /dev/null
Which seems to indicate that Frontview is doing what it should to power off.
does in fact shut the NAS down. Is there supposed to be a poweron entry? How does the NAS set and *do* a timed power on?
If it's via /sys/class/rtc/rtc0/wakealarm, putting in
cat /sys/class/rtc/rtc0/wakealarm
returns no value.
After looking around, especially in https://www.mythtv.org/wiki/ACPI_Wakeup#Using_.2Fsys.2Fclass.2Frtc.2Frtc0.2Fwakealarm (Handy!)
I did try a
echo 0 > /sys/class/rtc/rtc0/wakealarm
echo `date '+%s' -d '+ 5 minutes'` > /sys/class/rtc/rtc0/wakealarm
which returned:
1453510823
and then performed a
which 5 minutes later caused . . . nothing.
Any ideas on what more I can do from here? I was wondering if the rtc code in OS6 6.4.1 would work with my equipment, will 6.4.2 (RC1) address this, do I need a BIOS update, new mobo, or what more I could do.
I really only enjoy Rube Goldberg contraptions from a safe distance, preferably not on my equipment.
Help?
mdgm-ntgr
Jan 22, 2016NETGEAR Employee Retired
1. Power down
9. Power down
- kevinb1Jan 22, 2016Aspirant
Though not the most fun I've ever had, I did the above procedure.
The result was an update from
to
06/10/2010 FLAME6-2 V1.1
which now appears to work.
I might note that it's important, when updating from Raidiator 4 to To NASOS 6, to allow a full reboot after loading the new firmware and then let it go through an upgrade cycle, and not to do the factory reset until after you get a discovery error message.
Thank you, mdgm, for providing the solution.
Although I do wonder why Frontview's Admin Page>System->[power dropdown]->[Shut Down button] doesn't use (or perhaps add an option for) the /frontview/bin/autopoweroff sequence (including setting the RTC wakeup) so that the Power Timer can continue working after an shutdown originating from Frontview. Heck, maybe it could be a "Hibernate" button, nicht wahr?
It would seem to me to be an elegant way of keeping it working as designed, and saving the Big Blue Button for real emergency shutoffs.
- SkywalkerJan 26, 2016NETGEAR Expert
/frontview/bin/autopoweroff doesn't set up the RTC wake alarm. It just decides whether to shut down normally, or defer shutdown if volume maintenance is running. The RTC wake alarm will get set no matter how you shut down, so it already works the way you're asking it to.
- SandsharkJan 25, 2016Sensei
Perhaps it would be a good thing to put a message somewhere that warns users to upgrade the BIOS before upgrading to OS6. It is certainly a RITA to go through the upgrade to OS6 and full data recovery only to find one has to do it again because of BIOS issues. There might be one in that multi-page message about OS6 being compatible with legacy devices, but who is going to read through all that?
Would have been great on the old OS6 on Legacy subsection of the old forum -- too bad it disappeared with the new one.
