henry7629
Jun 27, 2016Aspirant
principle capacity rn104 ReadyNas 100 series Hard Disk
hi I have a disc of 4 Tb. another one of 3 Tb. at the most I can put in my rn104
- Jun 27, 2016
Hi,
I believe that the RN104 and other NAS's in that range support drives up to 8TB in capacity.
Note, that by default RAID is used, so unless you have done something to change that, do not expect the final capacity of your NAS to simply be the sum of all your drives. I think, that when RAID is active, you can expect to "lose" 1 drive of capactity as a "RAID tax" (thank you StephenB for a very apt term). Things get a bit more complicated when you start mixing drives of different capacities.
Ian
henry7629
terabyte maximum capacity that supports my NR104
ilneill
Jun 27, 2016Apprentice
Hi,
Ian
- StephenBJun 27, 2016Guru - Experienced User
The general rule for capacity is pretty easy - sum the drives and subtract the largest.
What gets a bit more complicated is knowing what size drives you can add (or replace). It is always ok to replace a drive with one of the same size. With OS 6 NAS, It is also always ok to replace (or add) a drive with one that is the same size as (or larger than) the largest drive currently in the array.
- henry7629Jun 27, 2016Aspirant
I have it in raid 0 and just wanted to know if you could add disks with more capacity for more general storage.
- ilneillJun 28, 2016Apprentice
Hi,
RAID 0, is not at all redundant. I think it is simply a mechanism to gain performance only. I believe that RAID 0 means that if you loose any single disk, then you loose all your data!
I have never ran any of my ReadyNAS's in RAID 0, so I cannot tell you how it actually works :-(
I would add that I would never consider running any NAS in that mode either. It is too risky for my liking.
Ian
