gixxer
Jan 21, 2014Aspirant
Pro Business Ed, odd power supply behavior, cpu hot, RMA ???
Hello, Background on this, ReadyNAS unit (purchased new few years ago), Model: ReadyNAS Pro Business Edition [X-RAID2] Firmware: RAIDiator 4.2.25 Memory: 1024 MB [4-5-5-15 DDR2] Volume C:...
menkelis
May 30, 2014Tutor
As a owner of a BE Pro6 with startup issues (took about 10 minutes) I can say that
after replacing the power supply the startup after switching on power is about 10 seconds.
With Software 4.2.x installed I also posted that on a 'shutdown' it is normal for the unit to automatically
power up after five minutes unless you set power switch to 'off' or unplug box. There is a script ran on
shutdown that sets the RTC to power on after 5 minutes if there is no pre-set power schedule.
