Muñoz
Nov 02, 2015Aspirant
Pro Pioneer Edition dead.
Hi,I have a Pro Pioneer Edition and i cannot reach it any more, when I start the NAS the display only shows Readynas and the network port leds are off,I tried to reboot it manualy with a peaper clip...
kohdee
Nov 02, 2015Administrator
Not sure if your issue is disk related or chassis related.
If you take out all of your drives and start the chassis, does it complain about not having disks on the LCD or does it still stay at Welcome to ReadyNAS LCD message?
Did you get any other alerts? Was the temperature CPU or disks?
If your ReadyNAS is responsive when there are no disks inside by telling you it has no disks, then it might be an issue with your disks.
If your ReadyNAS is still unresponsive, something may have happened to the hardware.
Muñoz
Nov 09, 2015Aspirant
Thanks for your quic response I took all the disks out and it wanted to boot, but then it seed ERR no disk, so I think it must be the disks.
What is the best thing to do now.?
I have 5 disks, and they where is x-raid2.
Is there a way to save my data?
- StephenBNov 09, 2015Guru - Experienced User
Well, the system needs a lot less power w/o the disks, so it still might be the PSU.
Did you test the drives with vendor tools (seatools for seagate, lifeguard for western digital)?
