jmalmlund
Jun 18, 2012Aspirant
Pro Pioneer memory upgrade, KHX6400D2LLK2/4G
For those who want to upgrade memory I can now confirm that Kingston KHX6400D2LLK2/4G (4GB 800MHz DDR2 Non-ECC Low-Latency CL4 DIMM (Kit of 2)) works like a charm (CAS memory timings are 4-5-5-18).
I'm running a virtual machine with Virtual Box as well as transmission bt, plex, Skifta and Cacti server and now everything runs much smoother (eliminated swap usage) so this was a really nice upgrade to me.
- ptmanAspirantAre you running the virtual machine on the NAS? Or just using it as disk image / iSCSI backend? Mind sharing your model number?
- jmalmlundAspirantThere's just one Pro Pioneer that I know of and that's the RNDP600E (that's what I've got anyway).
As for additional software that I run it's all listed in the first post (with additional I mean besides serving as a fileserver for my local network), don't use iSCSI at the moment. - mdgm-ntgrNETGEAR Employee RetiredYes there's only one Pro Pioneer, the RNDP600E-100. It's similar to the Ultra 6 Plus (RNDP600U-200). The Ultra 6 Plus is the follow on to the Pro Pioneer (basically the Pro Pioneer with some relatively minor hardware upgrades but still the same CPU). The Ultra 6 Plus itself has been discontinued now, I think. The Pro 6 (RNDP6000-200) with its faster CPU, 5 year warranty and business features is a great choice if looking for a new unit.
- jmalmlundAspirant
mdgm wrote: Yes there's only one Pro Pioneer, the RNDP600E-100. It's similar to the Ultra 6 Plus (RNDP600U-200). The Ultra 6 Plus is the follow on to the Pro Pioneer (basically the Pro Pioneer with some relatively minor hardware upgrades but still the same CPU). The Ultra 6 Plus itself has been discontinued now, I think. The Pro 6 (RNDP6000-200) with its faster CPU, 5 year warranty and business features is a great choice if looking for a new unit.
Thanks! Nice to see you complement with a few more model numbers but I just wonder, the Pro 6 (RNDP6000-200) you talk about, that's the "new" disk-less chassis option right? - mdgm-ntgrNETGEAR Employee RetiredYes. You can also purchase the Pro 6 with disks e.g. RNDP6310-200 (3x1TB enterprise disks) or RNDP6310D-200 (3x1TB desktop class drives) if you prefer.
The Pro 6 has a 2.6Ghz CPU which is a nice bump over the 1.8Ghz one found in the Pro Pioneer/Pro Business Edition/Ultra 6 Plus. See CPU Specs of the ReadyNAS. The Pro 6 and Ultra 6 Plus were released around the same time as each other, I think. - ptmanAspirantThank you. The memory upgrade seems to be working fine on our Pro Business:
Model: ReadyNAS Pro 6 [X-RAID2]
Serial: ***
Firmware: RAIDiator 4.2.21
Memory: 4096 MB [4-5-5-18 DDR2] - mdgm-ntgrNETGEAR Employee RetiredThe good thing about the Pro 6 is that it has a CPU with VT-x which is essential if you want to run 64-bit VMs in VirtualBox. This is one of the advantages of the Pro 6 over the first-gen Pro.
- zackiv31AspirantJust wanted to say thanks to jmalmlund for providing the successful install. Just received and installed my pair today. Ran two memory tests, and everything seems good so far.
Firmware: RAIDiator 4.2.20
I'll be running some UPNP->XBOX 360 media streaming that was giving me some stuttering. Hopefully this random guess of an upgrade helps out. If not, I guess I just gave the NAS a little more breathing space. - haavarstAspirantI would also like to thank Mr. Malmlund for his advice. Ran 5 passes of memtest without problems, and have now been using it for about a month without issues. Significant improvement in performance!
- edrouxAspirantThanks for your recommendation and success stories. Just ordered these for my Pro Pioneer. Does anyone have any experience with using these memory sticks on the Ultra 6 and Ultra 6 Plus as well?
Thanks!
