dabmd's avatar
dabmd
Pro Pioneer power supply died. Can I use the same HD array in a RN316?
My Pro Pioneer power supply died and I am having trouble finding a replacement.  If a purchase a new RN316 can I simply load the 6 disks and have it work without losing data?
  • StephenB's avatar
    Not quite.
    The RN316 will mount the volume as read-only,so you can copy off the data.  But the RN316 uses a completely different file system, and will have to reformat the drives.
    • dabmd's avatar
      dabmd
      Thank you Stephen.  So if I understand correctly, I could load the disks and then backup from the new RN316, then reformat the disks and restore the backup?
ProSupport for Business
