networkn
Aug 12, 2013Aspirant
Pro6 Fan Issue
Hi There! My Pro6 seems to have developed a problem with the fan, where every few minutes it will power up and power down almost incessantly. I am not sure how to start diagnosing the issue, but I ...
mdgm-ntgr
Aug 18, 2013NETGEAR Employee Retired
Open up the case and clean out the dust. You probably need to replace the fan. Should be able to get one with the right specs fairly cheaply.
