Stan78
Oct 10, 2020Aspirant
Problem installing applications
Hi there. So i bought my 2ns NAS from Netgear;) RN104 with 2x3tb WD Red installed. FW 6.10.3. Ofcourse 2nd hand but beautiful state;) Have problem though. GUI, smb, FTP, dlna, everything seems to b...
Oct 18, 2020Guru - Experienced User
KingC wrote:
I'm not sure if this is a siimilar problem that a fair few people are having or not, but any sugestions or ideas on how to get around this problem would be greatly appreciated
Yes, other people are seeing 403 also. FWIW, the reset isn't the culprit. New apps can't be installed on 6.10.3 systems, and I suspect app updates (for instance plex) will also similarly fail.
I reported this on another thread on the ARM systems, but didn't know if it would happen on an x86 ReadyNAS or not. Obviously it does. I've also sent a PM to the mods ( JohnCM_S and Marc_V ) - hopefully they will take care of the 403 error that is coming from apt.netgear.com.
I don't think there is any workaround for the 403, unless someone happens to have a mirror of apt.netgear.com that has the access permissions set properly. But it looks like the broken pipe issue is something else.
Still, I think the plex update would have failed even if you didn't have the broken pipe (as I think the update would still have needed to access libraries on apt.netgear.com).
Stan78
Oct 18, 2020Aspirant
X86 is also affected. I have RN ultra 6 on os 6.x and Intel CPU, and this has a problem too. So it looks like problem is platform wide / independent.
- watchme109Oct 18, 2020Tutor
This problem affects my RR2304, too.
- watchme109Oct 22, 2020Tutor
The only solution provided (in german community support) is: contact the paid support service!
- StephenBOct 22, 2020Guru - Experienced User
It should be working now - have you tried it again?
- TuvikOct 22, 2020Aspirant
StephenB wrote:
watchme109 wrote:The only solution provided (in german community support) is: contact the paid support service!
Indeed - seems to be fixed, at last!
Thanks
confirmed :-D
