ronron's avatar
ronron
Problem mount NFS after rest factory and update firmarework (1.10.3)
Hello,
 I had updated my readyNAS. I try to share my folder via NFS.
Spoiler
root@nas2:/data/sia-node1# cat /etc/exports
"/home" *(insecure,insecure_locks,root_squash,anonuid=99,anongid=99,no_subtree_check,rw,sync)
"/data/sia-node1" 127.0.0.1(insecure,insecure_locks,no_subtree_check,crossmnt,anonuid=99,anongid=99,root_squash,ro,async)
Any NFS options do not change the /etc/export. it is RO and the hosts do not change.
Why export home ?
From time to time, windows sharing is activated, it's super strange. While I want NFS only.
  • In the screen dump you uploaded, you are adjusting the SMB configuration, not NFS.  If you want to change NFS options, NFS must be selected in the second row of buttons.
    • ronron's avatar
      ronron
      Yes I saw that, under the old OS it was indication tags.
      Its tabs are a little bad
ProSupport for Business
