Michel-jacobs
Nov 03, 2017Guide
problem with sata one disk running at half speed
since a while my rn212 runs with disk2 running at half speed. after some googing this seems to be related to the power supply unit. Anybody noticed this as well?
Sandshark
Nov 03, 2017Sensei
Running at half speed? How so? The reported RPM is actually halved, or the transfer speed is?
0d0a
Nov 03, 2017Tutor
IT is THE transfer speed Thatcher halves according to kern.log ...
- Michel-jacobsNov 30, 2017Guide
after updating to os 6.9.1 the last lines of kern.log:
ata2: SError: { UnrecovData 10B8B BadCRC }
Nov 30 20:39:01 nas-jangali kernel: [ 1012.300158] ata2.00: failed command: READ FPDMA QUEUED
Nov 30 20:39:01 nas-jangali kernel: [ 1012.300172] ata2.00: cmd 60/e0:28:a0:dc:12/00:00:00:00:00/40 tag 5 ncq 114688 in
Nov 30 20:39:01 nas-jangali kernel: [ 1012.300172] res 40/00:28:a0:dc:12/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
Nov 30 20:39:01 nas-jangali kernel: [ 1012.300180] ata2.00: status: { DRDY }
Nov 30 20:39:01 nas-jangali kernel: [ 1012.300192] ata2: hard resetting link
Nov 30 20:39:01 nas-jangali kernel: [ 1012.650097] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Nov 30 20:39:01 nas-jangali kernel: [ 1012.651290] ata2.00: configured for UDMA/133
Nov 30 20:39:01 nas-jangali kernel: [ 1012.651314] ata2: EH completesupport says they got the wrong log files ... They want those from the web interface but that log does not include syslog let alone kern.log
should I be worried? The nas does function (still)
- StephenBDec 01, 2017Guru - Experienced User
The log zip file that you download from the web UI certainly includes kernel.log (among other things).
- Michel-jacobsDec 02, 2017Guide
yes. i stand corrected. It certainly does. I did not realize this, when one only views the log in the web interface one does not see any kernel messages however!
In the download there are all usual linux logs.
