Retired_Member's avatar
Retired_Member
Oct 19, 2020
Problems since Wifi mesh install
Hi I recently installed a new TP-Link Deco mesh system in my house. As my main router is no longer the management, the Deco provides a different IP address range. Since powering on my ReadyNas, I n...
  • Retired_Member's avatar
    Retired_Member
    Oct 24, 2020
    So found this simple solution installing Linux reader a freeware utility, installed one of the disks into an external hard drive and it did the rest and I was able to restore to another disk with easy.
    Here is a link, I would recommend this to others https://www.youtube.com/watch?v=nIWdZ0qDD54
ProSupport for Business
