GaryDD
Sep 23, 2017Aspirant
Problems with ReadyNAS
I thought it would be easy to upgrade to a 2x3Tb when a 2Tb drive died on Ch1. I was wrong. Would someone please tell me how to do this. I installed the 3Tb in Ch1, but it still says 'drive dead' in ...
GaryDD
I bought the new 3Tb drives from Amazon, they are unformatted. I have tried that, but will try again.
GaryDD
Even with the 3Tb drive removed, still shows the 2Tb drive as 'dead' - wtf?
- StephenBSep 23, 2017Guru - Experienced User
There are at least 2 possibilities.
One is that the sata port in the NAS itself failed, so it is not detecting any removals insertions.
Another is that the linux disk driver disabled the port when the old hard drive failed (if the drive were seriously misbehaving). Rebooting should fix that - if you already tried rebooting, perhaps try shutting down, removing the main power cord for a couple of minutes, and then power up with the bay empty.
- JBDragon1Sep 23, 2017Virtuoso
A NAS is not a backup solution. Hopefully you have a real backup. With only 2 drives, you should be in RAID 1. Which means everything is copied to the second HDD. So you should be OK and all your Data should be safe on that 1 HDD. You can only replace one HDD at a time, The NAS has the rebuild the system, when in your case would be format and copy everything over from the other HDD to the new HDD. If you replace the 2GB HDD with a 3GB HDD, it will only show up as 2GB. Think about it. You can't fill a 3GB drive and expect it backed up onto a smaller 2GB HDD. So it'll be 2GB until at such time as you replace the other 2GB HDD with a 3GB HDD and then it'll show as 3GB.
I would turn off the NAS, pull out the 1 bad HDD, leave the bay empty, turn it back on and boot up. You should be able to access all your Data. At this point, I would back up that Data to some other external HDD. Once backup up, Pop in the new HDD. As long as it's not formated, the NAS should see it and then install it and start the rebuilding process. If that doesn't happen, well you have a backup of all your Data. The best bet is to restart the NAS from scratch. Reformat both HDD in the NAS. As in start fresh, when done. Copy all the data you backed up back onto the NAS.
- GaryDDSep 24, 2017Aspirant
I unplugged the NAS overnight. In the morning I"m still seeing the old dead 2Tb. Plus, when I go to RAIDar Setup, I am getting an error "192.168.4.250 didn't send any data. ERR EMPTY RESPONSE" I obviously need a technician.
- StephenBSep 25, 2017Guru - Experienced User
I've never seen the EMPTY RESPONSE message, so I am not sure how that ties in. It sounds to me like the port on the NAS has failed - so as far as the NAS firmware knows, the 2 TB drive is still inserted and not responding.
The warranty on the NAS is 3 years for the original purchaser - you can check your warrany status at my.netgear.com.
I guess you could also do a factory reset, with that bay empty (living without it). You could try inserting a disk then, though I don't think it will be detected.
Unfortunately Netgear doesn't offer any repair services.
