Deal
Sep 13, 2019Tutor
Process for clean install of Logitech Media Server 7.9 on OS6
I have a ReadyNAS Pro Business (2008 edition) that I've recently upgraded the RAM and processor on in preparation for the jump from OS4 to OS6. One of the major uses of the NAS is as a music server a...
Deal
Sep 15, 2019Tutor
Can anyone see this post? No responses at all is unusual.
Thanks
David
- StephenBSep 16, 2019Guru - Experienced User
I did see it, but I haven't installed LMS myself. Hopefully someone who has done that fairly recently will chime in.
- DealSep 17, 2019Tutor
Thanks StephenB. Maybe you can help with a question about OS6.
I've got the firmware successfully installed last night without any apparent difficulty or errors (none in the logs). I loaded the prep4to6_0.1-x86.bin followed by R4toR6_6.9.5.bin without rebooting in between. After installation of the last .bin file, the unit rebooted and did a factory default as expected. Then the installation of 6.9.5 finished. Used RAIDar to find the unit and open the Admin page. It said there's an update available, as I expected, 6.10.1. So I updated to 6.10.1 successfully. None of this is the issue.
After successfully completing steps in the "wizard" to setup the volume, the admin page reported "Volume resyncing". It continued to resync for several hours and I went to bed. This morning I still see the message "Volume data is syncing (56.4%)" on RAIDar, and a similar resyncing message on the admin page. The system has been resyncing for several hours. This is surprising to me. I don't know what it's resyncing since there is no data on the volume. If it would still need to resync with a new volume, should it take many hours to do that?
This is a more informative graphic telling how long is left on the resync -- 6.5 hours.
