Tatsu's avatar
Tatsu
PSU fan replacement for Readynas Pro
Hi there,
I have RNDP6350 and unfortunately PSU fan very loud and the sound it makes is similar to tractor.
I use it as my home office backup and multimedia streamer so I have to change the faulty unit.
Can anyone recommend me a substitution for it?
Thanks in advance.
Tatsu
  • why not get netgear to replace the whole chassis?
    defective fans qualify for warranty replacements.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    +1. I'd also recommend taking the warranty replacement for the whole chassis.
    Voiding the warranty by replacing it yourself with a 3rd party part that may/may not work and may damage your hardware is not a good solution.
ProSupport for Business
