jcnalda
Jan 05, 2017Aspirant
Psu rnd4425
good afternoon
I have a rnd4425 and the psu has broken and within 2 weeks I do not get another one. Does anyone know if I can do another one with a pc power supply until the other one comes?
jcnalda wrote:
good afternoon
I have a rnd4425 and the psu has broken and within 2 weeks I do not get another one. Does anyone know if I can do another one with a pc power supply until the other one comes?This is an NV+ v1 (with -100 at the end of the part number, running 4.1.x firmware)?
If so you can temporarily use an ATX supply (external to the NAS) using a 20-pin ATX extender cable to get the power into the NAS. You do need to modify the pinout of the extension cable though - here's a diagram: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
- jcnaldaAspirant
Good afternoon thanks for the reply. But would not you have something more graphic? Something I can put into practice myself.
- jcnaldaAspirant
Where can I get the two yellows to replace with blue and white? Of the 4-pin connector?
- jcnaldaAspirant
Thank you very much for the answer but in this video http://www.evercase.co.uk/CompatibilityListReadynas.htm that saw coke just cutting the blue cable it is right how do I do?
thank you very much
