mrbangus's avatar
mrbangus
Putting drives back in correct order ReadyNAS RNR4000
I'm new to this community and do not have a log of knowledge regarding the ReadyNAS.  I just know that it's been running since 2009 and when a drive goes bad, we would hotswap them.
I know it's bad to say, but our device is just an afterthought, until we had 3 drives crash and not finding a whole lot of info on it.  I pulled 3 of the drives out (drives 2,3,4) and was going to replace them thinking possibly it would work.  But, it didn't.  So, now I was going to put the drives back in and see if I could possibly recovery the data off of them, but I do not know which drive goes in which.  I've read that the logs can tell me this, but I do not know which log to look at.  Any info would be helpful.  I do have logs going back a few years.  Thanks so much.
  • I'm going to need assistance with the data recovery. Can you please give me more information on your data recovery services? Thanks again.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Replacing three disks at once is not going to work. Your NAS does not have a dual-redundant RAID level option let alone a triple-redundant RAID option.
    If you were using X-RAID the relevant log is xraid_config.log
    You would also have to look at another log to confirm which disk was hdc, hde, hdg and hdi at the time.
    So you don't have a backup?
    Have you hooked up the disks to your PC to test them? You should e.g. test SeaGate disks using SeaTools or WD disks using WD Data LifeGuard Diagnostics.
    • mrbangus's avatar
      mrbangus
      Thanks for the info!  I actually got them back in order by looking at the "disk_identify.log" that was from July and found them by their serial number.  Such a relief!  Now, I'm going to number them and see if I can recover some data.
      Thanks again for your help.
      mrbangus!
        mdgm-ntgr
        Note that we do sell some data recovery services (we do software based data recovery only). It's definitely a help when users have had the foresight to download the logs before running into issues and have kept those in a safe place.
ProSupport for Business
