alexofindy
May 20, 2013Aspirant
Questions about new line
I have two readynas units, which until last evening were backups for each other. An older NV+ and a newer Ultra Plus 6. Last night, the NV+ died (probably the notorious PSU, which I can't seem to ...
May 20, 2013Guru - Experienced User
alexofindy wrote: ...Can the new units backup to/from the Ultra Plus line pretty seamlessly using rsync?
One clarification on mdgm's reply.
When you use the new products as a destination with rsync, the file timestamps have 1 second granularity. The rsync options in the new products are set properly to still allow incremental backups.
So if you are backing up your ultra plus to a new RNxxx, you want the backup job to be configured on the new unit ("pulling" the data).
