alexofindy
May 20, 2013Aspirant
Questions about new line
I have two readynas units, which until last evening were backups for each other. An older NV+ and a newer Ultra Plus 6. Last night, the NV+ died (probably the notorious PSU, which I can't seem to ...
nudist
May 21, 2013Aspirant
mdgm wrote: I think you misunderstood what I said. You can run the new ReadyNAS OS in a VM in VirtualBox on your PC.
It should be possible to install VirtualBox on the new ReadyNAS line. If you want to run VirtualBox I would recommend getting the RN516.
I aasume that in the second case you mentioned it should be possible to then run a windows guest under virtual box on the readynas
