alexofindy's avatar
alexofindy
Questions about new line
I have two readynas units, which until last evening were backups for each other. An older NV+ and a newer Ultra Plus 6.
Last night, the NV+ died (probably the notorious PSU, which I can't seem to find a replacement for), so I'm using the Ultra Plus 6, with data backup to an external USB-2 drive. I formatted the backup drive as ext-4 since in the past I've had trouble with using NTFS drives for backing up a Readynas, but this means if I ever need the backup, I'll have to do a bit of work.
So, I'm thinking about replacing the NV+ with a new system. I have to decide between one of the new readynas units, or a different brand.
A few questions:
Do the new units have any of the same expansion limits as the existing Ultra line (the 8TB/16TB limits)? The spec sheets suggest not, but then the published spec sheets and marketing blurbs for the Ultra Plus 6 didn't mention these limits either
Is expansion as versatile as some other NAS brands, which seem to let you expand with mixed disk sizes?
Can the new units backup to/from the Ultra Plus line pretty seamlessly using rsync?
Is Tivo archiving available? The spec sheets say it is, is this really true?
Finally, thoughts on the 316 versus 516? I think the 316 would meet my present and future needs, is a 516 worth the extra bucks?
Thanks!
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Duo/NV+ v2 replaced by 100 series
    Ultra /Ultra Plus/Pro replaced by 300 series
    Pro 6 replaced by 516
ProSupport for Business
