eveares
Jan 14, 2018Aspirant
Questions about the ReadyNAS 424
I am new here and am concidering getting a Netgear ReadyNAS 424. I currentley have a Asustor AS-5004T and want to upgrade it to something better what must incldude native windows based Fil...
mdgm-ntgr
Jan 14, 2018NETGEAR Employee Retired
1) No the RAM in the RN422 and RN424 is soldered on. If that is important to you you should consider the RN426, RN428 and the RN520 series. We don't support upgrading the RAM in any of our desktop units and we don't support using 3rd party RAM.
2) The RN424 uses samba for DFS. Samba is the Linux project that provides the SMB service. File versioning is done via snapshots of the BTRFS filesystem
3) Yes
4) We used to use one method for advertising SMB, but we now also use another for added reliability.
5) There is an option when creating a volume to encrypt the entire volume using an encryption key that'll be stored on a USB key. If the USB key is not connected the volume will fail to mount. You should have a few copies of the key on different devices (in case the USB key fails) and store the key in safe places.
